Sponsored by: CARiD
headlight pops up
Old Aug 16, 2005 | 09:09 PM
Clif19's Avatar
Default headlight pops up
When ever i put my alarm on or turn it off, the headlight pops up then goes back down. It just started doing this like 2 nights ago. Does anyone have any suggestions on how to fix this? I already tried doing a search and i couldn't find anything, let me know if you do. Thanks
Old Aug 16, 2005 | 09:16 PM
Nine Ball's Avatar
LS1Tech Co-Founder
is it also making a grinding sound when going down?
Old Aug 16, 2005 | 09:54 PM
stevensLS1's Avatar
if thats the case your gonna need a new headlamp motor.
Old Aug 16, 2005 | 10:40 PM
5w20's Avatar
cant you use the "other" half if it hasnt been used already?
Old Aug 17, 2005 | 01:49 AM
Clif19's Avatar
ok i just noticed that my passenger side headlight wont go up when i put on my headlights. I'm hoping its just the plastic piece that eventually breaks on pop up headlights, because the person i bought the car from had this happen to the other side and bought 2 metal pieces for both sides. You think the whole headlight poping up when i turn on the alarm could have been a warning that my other light wasn't coming up? I sure as hell hope so, or i have another problem With school starting and nothing being paid for yet, this will be interesting.
Old Aug 17, 2005 | 01:57 AM
regorih383's Avatar
sound like the wireing is wrong
Old Aug 17, 2005 | 02:25 AM
CRAGER's Avatar
Administrator
No thats what happens when the headlight motors are going/gone out.
Peace,
Craig.
Old Aug 17, 2005 | 07:10 AM
ACW's Avatar
ACW
Yep. Swap the gear and it should stop doing that
Old Aug 17, 2005 | 11:12 AM
CrawlinWS6's Avatar
Import Patrol
If your headlights are fliping up and down when you hit the lock buttom, and it is not making the grinding noise than it is your alarm settings, Go to your car manual and look it up and change it, if you don't like it.
If your headlights are grinding, DON'T buy a new headlight motor, that is GM's way of ripping you off, GM made those headlight motor unservicable, well so they thought, the noise is caused by the gear in the motor. The gear has some worn down teeth or broken teeth.
Turn your light up by putting the parking lights on.
Remove the headlight shroud. (3) screws
Remove the motor arm from the motor
Remove the bolts holding the motor in place. (The back bolt is a b#%&@).
Remove the motor.
Using a screw driver or a prying tool, carfully remove the cover, be careful not to crack the cover. (the cover is glued on)
Take out the gear and rotate it 90 degress either way, and put the gear back in the motor
Glue the cover back on,
Let the glue dry
Install the motor back in
INstall the motor arm
Put the shroud back on
check it out, see if its working properly
Wash your hands
Kick back on the couch with a beer in your left hand, and a blunt in your right hand and call it a day.
(Materials 1.50 for glue)
(Labor u did ur self)
(time 1/2 hour includes dry time)
Old Aug 17, 2005 | 05:49 PM
Clif19's Avatar
Ok well i went to put in the metal gear in this morning and i followed the video that was on the guys website were you get the metal gears from. I got to the part were i was about to move the headlight assembly out of the way to get to the motor and i realized i didn't have the right tool to get it off, so i was pissed. I could see the gear and i noticed it sure looked like the metal one and i realized that the guy who sold me the car told me he already fixed the passenger side not the drivers side like i thought yesterday. Well i was going to take it to Icon Autosports to see if Mike could fix it and as i put the headlight assembly back together i tried lifting and closing them again. Miraculously the headlight now works. I dont know how it happened but it goes up and down now everytime, and when i turn on the alarm, the drivers side headlight doesn't come up anymore. Thank God Thank you for all the information you guys gave me.
Old Aug 17, 2005 | 07:43 PM
5w20's Avatar
Remove the motor.
Let the glue dry
Wash your hands
this time....
GM ----> <----owner
