Sponsored by: CARiD
Wiring harness question
Old Aug 22, 2005 | 05:20 PM
XLR8TOR's Avatar
Default Wiring harness question
'00 T/A 'vert...
If you look up under the dash, above the brake pedal, there is a wiring harness coming through the firewall. It comes in below the master cylinder in the engine bay. What is it for, and is there normally a ~1/2" hole directly below it... kinda in the plastic part (not near the hood release cable)? I don't think the hole is factory, any idea what it could have been drilled for?
Old Aug 23, 2005 | 09:50 AM
Bens 2000WS6's Avatar
I believe you are talking about your OBDii diagnostics port. That is where you hook a computer up to check out your OBDII issues
Old Aug 26, 2005 | 06:01 PM
XLR8TOR's Avatar
Makes sense. Any idea on the hole near it?
Old Aug 26, 2005 | 07:00 PM
GM Muscle's Avatar
Many of the wires coming through that hole are for the ABS, few sensors, wiper motors, and stuff like that. Is the 1/2" hole just in the plastic matt, or straight through the firewall?
BTW: your diagnostic port is down by your right knee/shin if your stiing in the seat.
Old Aug 27, 2005 | 10:58 AM
XLR8TOR's Avatar
The hole looks like its mostly through some black plastic. There aren't any wires coming through the hole... the hole is just below the square wring harness "plug"
Yeah, I know where the OBDII port is.
Old Aug 27, 2005 | 07:53 PM
GM Muscle's Avatar
If it's molded into the plastic, it's factory. If looks alittle chewed up and drilled it's probrably not. The firewall has a single peice foamed backed preformed matt on it. It is possible the hole is where one of the push clips was. I just removed mine and I can't remember if there where any clips in that area.
Old Aug 29, 2005 | 04:32 PM
XLR8TOR's Avatar
Didn't look chewed, pretty smooth, and about 1/2" diameter. I just sealed the hole with some black silicone...
How big are the clips?
