Sponsored by: CARiD
low trac light
Old Aug 24, 2005 | 10:36 PM
69StrokerSS's Avatar
Default low trac light
intermittently while braking i feel a light grinding for a second and the low trac light comes on it also somtimes dose this if i hit second gear really hard the car does not have traction contol and the light has never came on other wise
Old Aug 29, 2005 | 08:50 AM
jkichline's Avatar
I had a similar problem on my 95 but I have Traction Control. It turned out to be a dirty ABS sensor connector right at the wheel. I forget which wheel. If you run an OBDII scan, it should show you an error code and tell you where the problem is.
Old Aug 30, 2005 | 07:30 PM
ok thanks i will check in to that
