Sponsored by: CARiD
Stripped plug
Old Aug 25, 2005 | 10:56 AM
xtinctbird's Avatar
Default Stripped plug
The plug on my # 1 cylinder was cross threaded when I pulled it out it took a little bit of the threads out with it(maybe a thread or two), the new plug goes in without a problem, can I get away with this or should I pull the head and have it repaired?
Old Aug 25, 2005 | 03:50 PM
dhdenney's Avatar
I would just chase it/tap it/rethread it. Shouldn't have to pull the head for that. Don't know about helicoil though cuz I would think you have to go to a smaller shank, but with plugs that's not an option. I haven't ever tried helicoil though.
Old Aug 25, 2005 | 04:19 PM
satinleafct's Avatar
Start it and see if it leaks. If it dosen't leak I woulnd't worry about it at the moment.
Old Aug 25, 2005 | 10:01 PM
xtinctbird's Avatar
Should I have to worry about any of the metal from the threads ending up in the combustion chamber, I figure they'll not be a problem but I want to be sure.
Old Aug 25, 2005 | 10:05 PM
Z284thgen's Avatar
i would only get really worried if the comp was over 11:1 about it blowing the plug bout out.... thats if you didnt retap the threads and make sure everything was good and sealed
