Sponsored by: CARiD
high battery voltage
Old Aug 28, 2005 | 04:10 PM
777's Avatar
777
Default high battery voltage
I just finished trying to do a motor mount swap, but couldn't get the bolts off so I just packed up and left put everything back together and now I'm getting off the chart voltage on the gauge. I assume the gauge is working as it doesn't immediatly jump to 18 volts. If I touch the gas the air bag light comes on and so does the check gauges. Can someone help me on why my battery would read such high voltage. I of course removed the alternator, but what could cause the high voltage? I don't see what could cause it.
Old Aug 28, 2005 | 08:56 PM
conan's Avatar
The voltage regulator on the alternator could be going bad. Did you try putting a volt meter on the battery to see if it wasent the gauge?
Old Aug 29, 2005 | 11:49 AM
777's Avatar
777
Problem solved. However, I don't know what was wrong. I just took it off disconected everything and put it back together. Evertyhing is fine now.
Old Aug 29, 2005 | 11:52 PM
tattooZ's Avatar
I call that 'control, alt, delete'.
Old Aug 30, 2005 | 12:15 PM
shandy294's Avatar
As far as I know,the v-reg.(part of your alternator) is the only thing that can allow the voltage to get that high(if its' bad). I changed a alt/reg on a friend's car because it was constantly 17 to 18v.
You might have a reg that is intermittently going bad.
