Sponsored by: CARiD
Spark Plug Install Problem
Old Sep 6, 2005 | 08:03 PM
02 SS's Avatar
Default Spark Plug Install Problem!!!
I have a 02 SS with 42k, a loudmouth and a lid. Today I installed the tr 55's. I kept the factory wires. I gapped them at .055. Everything seemed fine at first. Then I notice that under a load and full throttle it misses. I get a flashing SES light.
The wires look fine. Could I have damaged them while removing them. They were difficult to get off and I had to pull on the wire instead of the boot on many of them. Has anyone heard of this problem? Any help would be appreciated.
Old Sep 6, 2005 | 08:12 PM
85transamtpi's Avatar
Umm, flashing SES light is a definete sign of a miss... I have heard recently of people having problems with NGK plugs. I havent had any issues with mine.
Check all connections and verify that all the plug wires are seated all the way in the boots. I replaced my wires with aftermarket when I changed the plugs.
Old Sep 6, 2005 | 08:43 PM
snake charmer's Avatar
i would say you have a spark plug that is chipped, as said would check the spark plug wires and pull all plugs. you could get the codes read for free and know whick plug.
Old Sep 6, 2005 | 08:49 PM
Uno99's Avatar
Mine did the same thing as your. It was a cracked plug. replaced it and the car runs great.
Old Sep 6, 2005 | 10:44 PM
02 SS's Avatar
Where can I get the codes ran for free. I would hate to have to pull all of them.
Old Sep 6, 2005 | 11:11 PM
2000BLKSupersport's Avatar
Autozone maybe
Old Sep 7, 2005 | 12:46 PM
shaZZam's Avatar
My money is on #8 plug. That one is a bitch to change and the easiest to crack. Pull off your plug wires and inspect the plugs. Should be easy to see if a cracked plug is your problem.
Old Sep 7, 2005 | 08:31 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Factory wires are pretty good quality, but you could have damaged one yanking on the wire instead of twisting the boot.
NGK are darn good plugs. But if you cracked the insulator, that would give a misfire.
Make sure all plug boots and coil ends are plugged in tightly.
Tip: when you change plugs, use some dielectric insulator compound inside the plug/coil boots (don't put on the contact surfaces). I've changed plugs at least 4 times with my MSD wires and never had a problem.
#8 plug is -easily- changed from the bottom with the front wheels on ramps.
Luck,
Gerald
Old Sep 10, 2005 | 12:11 AM
J E T's Avatar
Spark Plug & wire installation
