Sponsored by: CARiD
good spark plugs?
Old Sep 10, 2005 | 07:05 PM
freshduckie's Avatar
Default good spark plugs?
OK changing out plugs, on a stock application except mirror mods,
should I go with NGK Ridium TR55IX?
Thanks
2001 ws6 m6 47,000 miles
Old Sep 11, 2005 | 03:17 PM
Pipelayaz's Avatar
I have the same question...personally I'm looking at getting Denso's.
Old Sep 11, 2005 | 03:20 PM
mrhzk35404's Avatar
me too
Old Sep 11, 2005 | 09:54 PM
cam75w/ls1's Avatar
Default Which plug to use???
I work as a mechanic for a living and can tell you the best thing to do is use what the factory uses. That means ac/delcos. I have had numerous cars come in for performance problems as well as dead misses on the motor from "bosch platinums" or the well known "split fire" plugs. the plugs may be designed to be "100,000 mile plugs" but won't last that long due to carbon build up or oil consumption.
Old Sep 12, 2005 | 10:34 AM
So the stock plugs are a ac delco, are they copper plugs, is just ac delco the full name?
Old Sep 12, 2005 | 10:58 AM
SporkLover's Avatar
I use NGK TR55's and I have not had a problem at all with the car or missfires.
Old Sep 13, 2005 | 04:16 PM
A BAD T/A's Avatar
Some cars came with NGK, others with Denso plugs. ALL OE plugs were double platinums. Mine went 72,000 mi and still looked good but putting in a new set of Denso's made the tires bark 2nd like it used to!
