Sponsored by: CARiD
low coolant warning?
Old Sep 12, 2005 | 08:18 AM
GDM Z28's Avatar
Default low coolant warning?
every once and awhile the car will throw a low coolant warning....today i got off my lazy *** and checked the coolant and it was full.....does this mean its a faulty sensor? what else should i check? TIA
-Trent
Old Sep 12, 2005 | 09:16 AM
GregWS6&z28's Avatar
sensor can be faulty or it can be that your radiator cap isnt holding the correct pressure.
dealership replaced my sensors, and was about to pull the heads because they thought it was a blown head gasket and it ended up only being the cap
Old Sep 12, 2005 | 11:13 AM
GDM Z28's Avatar
i read a post earlier and a guy with the same symptoms said it was the sensor and i guess the 98's & 99's had a problem with them....im gonna change that and if it doesnt go away ill change the cap as well....ty for responding though.
Old Sep 13, 2005 | 09:48 PM
Phoenix 5.7's Avatar
SDPC--> has it. i have that problem also, full coolant and have the light on. now if i can get my lazy *** up and put on the sensor
Old Sep 13, 2005 | 10:03 PM
Speed Density's Avatar
hashtagBMW
jsut a sensor man thats allit is.
