Sponsored by: CARiD
A4 Idle Vibration
Old Sep 19, 2005 | 09:03 AM
Rt66er's Avatar
Default A4 Idle Vibration
The car is a 2004 GTO with auto tranny. Problem is that after fully warming up, it exhibits a bad vibration felt throughout the car. It gets worse the warmer the weather, i.e., when the temps are 90-100 degrees outside and the A/C is engaged at idle in "D" it vibrates so badly that the dash starts to buzz. Feels like you're sitting on a big vibrating pager. This is not cam shake; this is a constant low-frequency vibration that, when it is really bad, you can actually hear. When the car is in open-loop it seems fine, but of course the idle speed it higher then, too. It exhibits this problem all the time (after warm up) but is worse with the A/C on and then a bit worse when the fans are running. I don't know if this is a contact-related problem or a malfunctioning part (IAC, etc.). It started this about two or three weeks after purchase and I have had it back to the dealer 4 times; their only solution is to hang weights on the exhaust system to dampen out some of the vibration. I have tried adding bushings to the exhaust hangers to get rid of all play in the exhaust and this helps, but I think it is just reducing the symptoms rather than fixing the actual problem. Idle speed in D is correct at 550 rpm (per Predator monitoring) and IAT sensor seems to be functioning. I can just rest my foot on the accelerator pedal and slightly raise idle rpm (maybe 75-100 rpm) and the idle smooths out perfectly. Any suggestions would be welcome at this point.
Old Sep 19, 2005 | 03:36 PM
Pewterpower's Avatar
Could it be belt related? Like a pulley or balancer?
