bucking/clunking from M6
ive noticed that the higher the gear im in the more it tends to show itself.
picture driving down the road in 4th gear at around 2k rpm and you give it a little gas to keep it going and u let off and you hear/feel a slight clunk comming from somewhere between transmission and the rear-end. it never clunks when giving it gas in the same situation but it will slightly buck back before actually moving.
it only really shows itself in 3rd 4th 5th and sometimes 6th
it will also cause a clunk noise if im rolling in gear and push in the clutch which is a lot more noticeable in 1st and 3rd and 4th. and a lot when shifting gears mainly 2-3, 3-4, 4-5.
i beleive this clunking is related between rolling in gear and feeling/hearing it and pushing in the clutch while rolling and it happening.
no to the things ive done and checked to try in prevent this:
transmission rebuilt(helped slightly for a little bit)
replaced transmission mount(no luck)
replaced torque arm mount(no luck)
rear-end gears replaced(might have made it worse)
if i cant fix this problem soon im going to shoot myself in the head, it makes it to much of a pain to drive it. ive driven numerous other M6 fbodys and non of them are this bad.
if i could blame one thing it would be the 4.10's
PLEASE HELP and thank you for reading my blurb.
right now im using the stock torque arm, i had a BMR adjustable and still acted the same.
1st gear doesent really clunk but it will buck back and forth a lot if i ride it up a little and let off or if i try to idle rolling in first.
when my car was in for repairs after a minor accident
i had commented on the noise/clunk and he mentioned the technician had mentioned something about having slack in my spider gears.
this is one thing i have not checked into yet, but i beleive this could vary easily be the culprit......stay tuned.
Things I have done to solve the probelm.
Rebuilt trans
NWB Bushing
Pilot Bearing
All new hydraulics
Tex OZ700
Poly Motor and trans Mount (Both prothane)
UMI LCAs
UMI Panhard bar
S60 rear (checked, lash is good)
strange driveshaft (rebalanced and checked twice)
I am running the stock torque arm, mount and bushing. I will be picking up the poly bushing tomorrow.
Any ideas would be appreciated.
The splines get worn out over time, and they cause play between the axles and the side gears in the diff.
The best way to check it is to pull the differential cover, hold the ring gear, and turn the wheel back and fourth to feel for play. If you can move the wheel enough to hear the clunk and the side gear never moves, you've found your clunking problem.
Its not something to be overly concerned about performance wise, its mainly just really annoying. You could try buying a set of Moser axles and see if that eliminates the play.
My problem has added a couple of symptoms:
A clicking noise from the rear end from a stop,
Also when I veer to the left around 30mph I get a metronomic thudding from the passenger side of the rear end.
I wonder if it has to do with a worn axle...
Same issue for me..mods in sig. If I punch it in 1st and quickly let
off I get the bucking feel from the rear end. Did anyone ever find
a solution to this? It never did this when I was stock that I recall.
I've checked every bolt that I can think of and banged around under
neath with a rubber mallet. Nothing is popping out at me.
My shifter doesn't jump at all.
I've changed my diff fluid..looked decent.
I'm debating either replacing my torque arm bushing or just
getting a founders adjustable. But I don't want to just throw
random parts at it..
