Sponsored by: CARiD
starting problem on lt1 formula
Old Sep 22, 2005 | 01:08 AM
ncd1966's Avatar
Default starting problem on lt1 formula
ok my friend has a 97 formula and the car takes a couple of cranks to fire up.
After it starts it runs fine. He just had the whole ignition system changed including opi-spark, new wires and plugs. Someone told him that it was his ignition relay. hopefully we can find the problem
Old Sep 22, 2005 | 03:08 AM
sssalah's Avatar
Check the fuel pressure, maybe it's bleeding through the fuel pump check valve too fast. Try priming the pump a couple of time before starting her up.
