Fresh 427. Need help with noise!
Squealing is not a good sound, especially if it's not coming from the belts.
Did he build the motor himself? Is the car an automatic?
I'm not suggesting to start and run it but if you do, take a broom handle and put your ear to it and place it on various points in the engine to determine where the noise is coming from at the engine.
Try that, check back...
Honestly, it may be a spun bearing so please don't run it anymore. If he wants to find the issue, then have at it.
It may also, maybe, possibly be the clutch/flywheel contact. How was it installed? Torqued correctly? I doubt this but it's still a small possibility.
Tell him RED High Temp RTV works great in a time of need, to replace a gasket surface. I've used it before, let it tack up, then apply part and bolt down. Hell, I recently used some on my new drain for the bathroom sink.
It works GREAT ! The Best V8 Stories One Small Block at Time
issue or a possible issue can be bad and ruin motor parts beyond saving. It's good he's getting it sorted out.
