Sponsored by: CARiD
Pulsing lights
Old Sep 24, 2005 | 08:25 AM
Billy_B4C's Avatar
Default Pulsing lights
Anyone have any idea what might be causing all of my lights to pulse? It doesn't vary with RPM, and it is ALL of the lights - headlights, interior, tail, dash, etc. The alternator is showing erratic charging...could that be going bad?
Old Sep 24, 2005 | 09:54 AM
35thUCF's Avatar
My roomate's SS is doing that also, only in park at very low RPM, but he as an optima red top, and it shows full volts. i would check continuity with a multimeter at all your grounds and power leads. My 79 Corvette did this, and I had to re-ground half the wiring harness due to damn beach corrosion, good luck man
Old Sep 25, 2005 | 12:17 AM
Sartobuilt's Avatar
Mine is doing the same thing. Im betting its a ground. I'll let you know. witch one it was.
Old Sep 25, 2005 | 01:57 PM
JonB's Avatar
I've noticed mine does it sortly after i start it up. It usually only does it once. I've figured that it is the air pump shuting off. The air pump is usually on of a short while then it shuts off once the cats are warmed up, and the lights flicker. You can usually hear when the air pump turns off. If there flicker all the time constanly then its not this.
Old Sep 26, 2005 | 12:51 AM
hawaiiboysz's Avatar
I had this issue w/ my black car I brought it back for warrantee work. It was wiring they had to redo a ground or something. I have the paperwork in storage since now I am overseas.
Old Sep 26, 2005 | 11:00 PM
Sartobuilt's Avatar
My 2002 M6 was flickering headlights and also radio static when using the power windows.
All I did was tighten the ground on top of the pass side inner fender and the problem is gone I have seen this alot over the years. Gotta have good grounds.
