Sponsored by: CARiD
stuck @ WOT
Old Sep 19, 2005 | 01:54 PM
Red Cell's Avatar
Default stuck @ WOT
sometimes accelerating to up shift, my throttle would fly up to the rev limiter,
I have to shift to 6th or just kill the ignition while in motion to fix this.
could this be a computer issue or something else making my TB stick open at WOT?
im not really driving the car anymore mainly because im afraid to get killed or hurt someone else.
98 camaro ss m6
Old Sep 19, 2005 | 02:04 PM
Roarin_8's Avatar
Check the TB out to see if there are any obstructions and check out the cable as well. Maybe it's getting caught somewhere?
Old Sep 19, 2005 | 02:19 PM
Red Cell's Avatar
last time it happened I killed the ignition, popped the hood ( in the middle of a 4 way intersection) and closed the throttle body blade.
It was kinked/stuck wide open. Then i went to start it and it went WOT again, just on starting it, i didnt touch the throttle at all. I got out and closed the TB blade again and was able to put it into 3rd to get it off the street then home.
I saw that the cruise control was on at the time of the last problem.
Also there are 2 cables, 1 I think is the cruise control cable? it was disconnected.
I will have someone look at it asap.
Old Sep 19, 2005 | 03:30 PM
Pewterpower's Avatar
Yes, the second cable is Cruise Control. What happens when you step on the gas (engine off, hood open, and watching the cables while a buddy works the pedal)?
Do you see anything being kinked up or not right?
Old Sep 21, 2005 | 08:12 PM
Red Cell's Avatar
Pewterpowre, I have noticed that when I go to manually close the TB, the throttle cable jumps.
Is this a common problem with an out of whack TB/cable? stuck @ wot?
I havent had a chance to have it looked at yet, Im in the process of moving.
Old Sep 22, 2005 | 10:08 PM
What do you mean by "manually" closing the TB? Cuz the TB is spring loaded closed. Do you not have a spring there?
Old Sep 24, 2005 | 02:20 PM
Red Cell's Avatar
It sticks open, i have to kill the ignition, get out of the car and close it by hand =(
Old Sep 24, 2005 | 02:49 PM
cam75w/ls1's Avatar
Default Stuck at WOT...
Check to make sure the return spring on the throttle body is not broken or missing... Also check for fraying of the cables. Sometimes you can't see the frays and need to take both the cables off the throttle body and check for snagging in the cable housings. I don't mean to make you sound stupid but I have seen the floormats get caught on the acclerator pedal as well. Check that as well....
Old Sep 24, 2005 | 06:34 PM
slowpoke96z28's Avatar
check the throttle return spring. if not that unplug the traction control module or the cruise control module and see if either of these fix the problem.
Old Sep 24, 2005 | 06:38 PM
Vax's Avatar
Vax
sounds like the spring for his is missing, and air pressure is pushing the blade open to WOT, no resistance to close it. heh
Old Sep 25, 2005 | 01:58 AM
Red Cell's Avatar
I drove the car to the new place im staying at and will have it fixed real soon.
I have a better idea now to whats happening.
Old Sep 27, 2005 | 12:06 AM
HOSS's Avatar
damn, i had a piece of asphalt between in between the bumpstop, and it caused it to stay at about 40 percent throttle, that **** freaked me out.lol
