Rough Idle and Surging
2000 SS, MN6
Well here's the story, just changed the fuel filter, new SLP air lid (removed my Direct Flow, it was cracked), new air filter. I took off my MAF ends and just looked at them to make sure they were not dirty and the screen was not clogged. Oil change with Moble 1 10W30 and Moble 1 Filter (M107), new PCV valve and new plugs, NGK TR55 IX (Iridum) gapped checked out of the box at 0.57-0.58 left them they way they were. Also did a Seafoam treatment, sucked half the bottle slowly throught the PCV hose, let sit for about an hour and then ran the **** out of it. Not much smoke at all. I did this before I did the oil change and plugs. Oh yeah checked my EGR and the O ring that I replace 4 years ago was cracked replaced that with another o ring.
Now all of a sudden the idle is choppy (feels like a a mis or something) and there is surging when I'm starting from a stop only in first gear, and sometimes when I grab second. But the weird thing is that once I'm in gear and above 2000 rpms the engine is smooth, now burps hicups or surging. Cruising and 1/2 to 3/4 throttle is also fine. Sometimes the surging upon acceleration is not that bad and sometime not at all, sometimes it's horrible.
When I was doing the plugs, on the drivers side I had to remove the 2 wire plug/sensor off the head right near the front of the head, and I did start the car with that unplugged (forgot to plug it in), what is this? Temp sending unit? Also on the passenger side I had to remove the AIR tube of the manifold to get to plugs #2, 4, 6. I did not replace the aluminum gasket. Also wire #8 gave me a hell of a time getting off I was under there for at least a half hour wrestling with this. Plug came out easy though.
I checked the PCV system, where i left the hard line PCV open to the air without the PCV valve installed and capped the Throttle body and it still had a crappy idle and surging. I re-seated all the plug wires except #8 (did not have time to put car up on jacks.
And last thing, this is the first time that i actually drove the car up on my Rhino Ramps, I usally jack up and put the car on the ramps. Well I can tell you that I know I burnt the clutch a little because when i got it up there, finally, I smelt buring clutch.
I already ordered new wires and replacement gaskets for the AIR tube to manifiold. I will check #8 wire today. But what else can this be. Please help
Obi Wan your my only hope.
Thanks
Nick F
this is a text book desciption of a dirty IAC (idle air controler) is it located under your throttle body, if it gets dirty/grimy/wet it does all of the above exactly as you have described, and guess whenn 99% of the time it happens to people is? right after they did 5-6 mods/tuneup things/ cleaned engine bay at once
take it out, clean with isopropanol and replace, 99% sure that will cure your trouble, if not the second place i would look (since you did mess with it) is your MAF, clean it with isopropanol as well...
let us know how it turns out...
Thanks
Nick F
This morning, also did a IAC reset, did nothing. Please Help
Thanks
Nick F.
pull your battery cables and leave off for 30 mins, reconnect and drive around for 30-40 mins so the car can relearn itsself...
also did you clean your MAF too?
