Sponsored by: CARiD
vibration at speeds of 70 and over
Old Sep 24, 2005 | 10:20 PM
mikey1000rr's Avatar
Exclamation vibration at speeds of 70 and over
well this started after I change my trans mount and tq arm bushing with energy suspension ones.but I have also notice that when I put the car in neutral at about 80 or 90 mph the vibration goes away somewhat.what can it be?I HAD THE CAR ALLIGNED TWICE AND THE WHEEL BALLANCE BUT STILL THERE I TOOK THE SPACER OFF THE TRANS MOUNT BUT NO DIFFERENCE.HAS ANYONE EVER EXPERIENCE THIS? THANKS IN ADVANCE
Old Sep 25, 2005 | 08:14 AM
XLR8TOR's Avatar
Is the new trans mount the same height as the old one? If not you changed the angle, and caused a vibration. The vibration will (over time depending on how bad it is) either destroy your tailshaft bearing or your pinion seal.
Old Sep 25, 2005 | 09:40 AM
So Besides Replacing It With A Factory One How Can I Work With The One I Got Its There Anything That I Can Do To It
Old Sep 25, 2005 | 08:53 PM
well I just found the problem I grind the 2 humps on the mount and added 3/8 nylon washers between the brace and the frame and its smoth like a new car.Ill leave this posted incase someone has the same problem
Old Sep 26, 2005 | 05:42 PM
XLR8TOR's Avatar
Yeah, you want to make sure the one you swap in will have the same height as the one you swap out.
