Sponsored by: CARiD
what battery to use?
Old Sep 28, 2005 | 04:35 PM
98RedBird's Avatar
Default not sure where to post this
ok, the battery, i think, is shot on my car. i was going to obviously buy a new one and i was looking around, is optima the way to go, or will pretty much any battery do. the reason that i ask is because optima is like twice the price about $130. what battery are you guys running?
Old Sep 28, 2005 | 04:41 PM
777's Avatar
777
Optima should be closer to $110. However, you are correct it is very expensive. You could get by with another battery, you just need to make sure it has the right specs as far as cold cranking amps go and stuff.
Old Sep 28, 2005 | 05:06 PM
2001NBMZ28's Avatar
I couldn't afford an Optima when my Delco went caput - bought a DieHard.
Old Sep 28, 2005 | 05:13 PM
98RedBird's Avatar
but is there really a performance diff. as long as the CCA is the same
Old Sep 28, 2005 | 05:17 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I'm using a Delco Professional in all my cars. I've gotten 6 years out of these in the past, probably could have gone 7+ but we get some pretty cold winter days here so I didn't want to wait for an issue.
The Delco Professional is better than what comes off the assembly line stock in these cars.
Old Sep 28, 2005 | 05:36 PM
777's Avatar
777
They are gell batteries and they weigh less. I think they would be better for autocrossing and sub 11-12 second drag racing.
Old Sep 28, 2005 | 09:28 PM
msbz_ls1's Avatar
My battery was $70 its AC Delco like what comes in them from the Factory or atleats mine did
Old Sep 28, 2005 | 11:11 PM
98RedBird's Avatar
i went ahead and bought the optima redtop. looks good in my red T/A...... i know it sounds dumb, but the redtop battery in the engine compartment looks pretty good.
Old Sep 29, 2005 | 03:18 PM
chris2000ss's Avatar
i'm using a optima yellow top and couldnt be happier.
Old Sep 29, 2005 | 03:20 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Good choice there.
Old Sep 29, 2005 | 04:02 PM
lsp408's Avatar
the problem with regular battery is the leak. i have seem many people's ride where battery 's been leaking, everything under the battery is rusty!!!
and that white **** corrosion at the terminals!!! opitima will sovle the problem
