Sponsored by: CARiD
bad sound in first gear
Old Sep 30, 2005 | 12:17 AM
TTU98SS's Avatar
Default bad sound in first gear
Im not sure if this is in the right forum, if not feel free to move it no problemo
When I stomp on the gas in first gear I get a very bad sound, that i can actually FEEL right below me. At first we thought it was the tranny mount, nope. Then checked the driveshaft, nope. Anyone got any ideas to what the hell it might be, its quite loud and definitely NOT normal. It also happens a little in second if i really nail it and when im in the high RPMs I get pretty bad vibrations... HELP!
Old Sep 30, 2005 | 12:23 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Maybe the exhaust hitting the floor when large amounts of torque are applied? Is the Y-pipe or headers really close to the floorpan? Maybe as the motor mounts are aging they are not able to hold the twisting force of the torque as well hence the issue just developing now?
Old Sep 30, 2005 | 12:31 AM
TTU98SS's Avatar
well I looked at the Y pipe when I was under there and I didnt see any real significant scraping or anything, I dont know of a foolproof way to check for that?
Old Oct 1, 2005 | 11:20 AM
Zymosis's Avatar
My y-pipe actually rubbed on my drive shaft. And there were no marks on the drive shaft and only a slight mark on y-pipe. And it made a god awful noise i dont want to hear again.
Old Oct 3, 2005 | 03:38 AM
TTU98SS's Avatar
Got in there tonite and replaced the TA mount.... not the problem. Almost POSITIVE y pipe/headers/any exhaust is NOT the problem, you would know if you rode in the car. Im running out of ideas!! HELP!!
Old Oct 3, 2005 | 10:51 AM
canadian z28's Avatar
trans is done!
Old Oct 3, 2005 | 12:56 PM
TTU98SS's Avatar
i dont think so.
Old Oct 3, 2005 | 01:35 PM
Could be the bearings at the input or output side of the trans. Try draining the fluid and see what comes out. Check the color.
Old Oct 3, 2005 | 01:36 PM
Could be the bearings at the input or output side of the trans. Try draining the fluid and see what comes out. Check the color. Do you feel it in the shifter with your hand on it?
