storing car in the winter?
Park it on Cardboard...
Put it on blocks. If you don't put it on blocks, inflate to 40psi to avoid tire damage
Fill tank completely use fuel stab
Change your fluids
Change your fluids
but your exactly right, you have to let it run for at least 30 minutes, even longer if its really cold
i usually wait until its "warm" that month, and start it up until the fans kick on to cool the engine, then i rev it a little bit to blow the extra water out of the tail pipes
but my WS6 has a stainless exhaust so it doesn't matter so much
Cold pipes/engine/parts will cause the moisture to collect inside those parts like water on the outside of a glass of cold water (remember the water pouring out of the exhausts of cars in front of you at the lights on cool days?) You have to run your car not only long enough to warm up, but to get hot enough long enough to evaporate all that moisture out of your systems. If you don't, it accumulates and causes acids and rust. That's a damn lot of idling over a winter!
It's my opinion that a single startup at the end of a few months' storage is better.
$.02.
I can see I won't be changing anyones minds, but running your car, no matter how long, will create heat, and once the cooling proccess beings, you create moisture.
Moisture = rust
Starting your vehicle creatres moisture
1) Change the oil. Water bad
.2) Disconnect the battery. The security system slow drains it.
3) Fill the tank and add some gas drier to absorb water from winter temperature swings.
4) Jack it up to get it off the tires. I'd be leary of leaving it set for even 3 months on expensive tires. Wrap the tires up in some big hefty bags to minimize oxidation. The bags may be overkill for a single season, but mine is in year around for now.
5) A friend starts it up about every 6 weeks, warms it up to operating temp, and revs her up a bit just to remind her who she is.
6) Maybe, maybe not, but I put about 10 lbs of a water absorbent in a bucket in the back seat to keep the humidity down. Of course, it's low in winter ayway, but again, mine is in year around for now.
7) Cover it with a drop cloth to keep the dust off your paint.
8) Tell her you'll miss her
That's it. No worries.
BobP
