Sponsored by: CARiD
Overheating? Water pump?
Old Oct 4, 2005 | 07:55 PM
mag2001's Avatar
Default Overheating? Water pump?
I was on my way to work and saw my temp gauge real close to the red part so i pulled over and let it cool down than i went home. I drained my radiator and changed my themostat and put new antifreeze the orange one and it still overheats when i put it back together.
is it my water pump
is my water pump electric or driven by something? i am not to educated on this so sorry for the dumb questions
If it is my water pump what is the best one to replace it with?
Also can it be an air pocket in the system?
It is a 2001 trans am
Old Oct 4, 2005 | 11:25 PM
Carter Hays's Avatar
Bleed the air from the system and see what happens. No, the pump is not electric. Remember start simple
Old Oct 5, 2005 | 04:13 AM
jkichline's Avatar
Yeah,
Most likely it is air. That happened to me when I changed my anti-freeze. Took me a couple hours to figure it out. I would start the car and watch the temperature gauge just run away. I figured it must be air because the temp cooled in about 5 mins without the engine running. There is a bleeding procedure for your car that definitely needs to be followed. If you have a 2001, I think this thread should cover it.
Air bleeding
Good luck man!
Old Oct 5, 2005 | 04:17 PM
mag2001's Avatar
Thanks guys i disconected the hose on the driver sie and it worked no more over heating.
