Sponsored by: CARiD
starts and stalls
Old Oct 4, 2005 | 08:31 PM
ricknbird350's Avatar
Default starts and stalls
i fixed the no start problem it was a blown ignition fuse in the engine compartment.
every morning i start my car...it start and stalls...it happens atleast 10 times...till it actually idols.
when the car is cold it runs real lean. so i changed the temp sensor and still does it. so what would u guys recomend i try?
if i turn the key on my fuel pressure goes to 45psi then drains back down. i thought it was the check valve, and i thought the check valve was in the pump so i changed the pump and its still doing it any ideas? i changed the injectors too and its still doing it....
