Change Oil Light Reset
Thanks for the info... I did it myself...
press eng met on the trip monitor then within five seconds press it again
within five seconds press and hold "gauges"on the trip monitor the change oil light should flash
hold the "gauges" button till the change oil light stops flashing and goes out this should take about ten seconds when the light goes out the monitor is reset if the monitor does not reset turn the ignition off and try again
it should be on page 94,95 in the owners manual
