Sponsored by: CARiD
replacing L front turn signal
Old Oct 17, 2005 | 07:05 PM
Danger731's Avatar
Default replacing L front turn signal
is there a link to this? There are too many brackets in the way for my arm !
Old Oct 17, 2005 | 07:26 PM
Danger731's Avatar
also it seems that the bulb housing just doesn't pop,turn or snap off like the other bulb housings on the car.
Old Oct 17, 2005 | 08:50 PM
ZeeVert's Avatar
What do you have... Camaro, Firebird, Tahoe...?
On my 02 Camaro, I'd remove the headlight first. The socket is about a 1/4 turn style.
Old Oct 17, 2005 | 10:23 PM
komik's Avatar
I'm guessing it's not a 4th gen firebird. Our front turn signals are easy to replace.
Old Oct 18, 2005 | 04:24 AM
98A4LS1's Avatar
I just did drivers side front TS on '98 Camaro. You need to remove the black plastic cover from underneath the car to gain access to the bulb and white plastic housing. This allows more arm room to reach up and twist the bulb and it will come out. On mine the housing was all corroded from moisture.
Old Oct 18, 2005 | 07:04 AM
demonspeed's Avatar
It's not mine! woo hoo!
It is SUPER easy to change the turn signal if you pull the headlight out. The headlight comes outin like 15 seconds.
Old Oct 18, 2005 | 09:39 PM
2002CobraKiller's Avatar
to me the easiest way is just to take off a couple of the bolts that hold the plastic on in front of the air dam stick your hand in there and youll feel the bulb.
