Sponsored by: CARiD
Key will not turn in Ignition!
Old Oct 18, 2005 | 10:43 PM
BlackZCamaro's Avatar
Default HELP!!! Key will not turn in Ignition!
I don't know what forum this goes in, so if it needs moved, so be it.
I have a friend who own a 1995 LT1 Camaro, and he cannot turn the key over in the Igntion. He has tried everything to make it turn forward, and it has never done this before. What could be wrong with it, and how do we go about fixing it ASAP?
Links? Suggestions? Instructions? Anything is appreciated!
Old Oct 18, 2005 | 11:01 PM
97PredatorTA's Avatar
If I'm understanding you right, I had the same problem. If its the same thing that I had, your screwed. It was a while ago and I don't remember exactly what was wrong, I just remember the key wouldn't turn, so I brought it to the shop and they had to replace the whole ignition or something like that. It was locked up or something. It was pretty pricey. Might not be the same thing though.
Old Oct 18, 2005 | 11:13 PM
BrandonDrecksage's Avatar
sometimes mine gets a lil stuck and I have to jsut jiggle the sterring wheel a lil bit and it frees up...does he have a spare key to try?
Old Oct 18, 2005 | 11:25 PM
Camaroz's Avatar
you mean the steering lock...
Old Oct 18, 2005 | 11:35 PM
no..its not off topic. sometimes..i'll try to turn the key..it won't turn..I move steering wheel...then key turns....how is that off topic?
Old Oct 18, 2005 | 11:37 PM
I've read a couple things on here pertaining to Lock Cylinder replacement and it seems like it continually points me in that direction. I've also read somewhere a while back that you could buy the lock cylinders from GM still?
Brandon: The car was started in the owners Driveway and left to idle up to Op temp, and when he turned it off, came back later that day, it would not turn forward or backward in the lock cylinder.
So it's definetly ruled out the steering lock.
