heater only blows cold
The weired thing is one time in the middle of the day I let my car sit while running and the temp went to 210 so I turned on the heater and still it blew cold. If anyone has any ideas please let me know. Thanks for any info you could provide!!!
Couple things to check....
1) Fluid level and make sure the system does not have any air... Maybe the fluid is not making it to the heater core. If you've ever replaced the fluid, you need to bleed the system properly. Many TA owners forget to do this (including myself).
2) when you turn your temperature controller to hot... make sure that the **** is actually turning the shaft behind the **** to hot.... You should be able to pull the **** straight off and see what position it is in...
3) It could also be a vacuum problem as the climate control is a vacuum system. I'm not sure how to troubleshoot that part....
By the way, when your air compressor runs, your radiator fans are supposed to also be running.
okay now, is the AC suppose to be on in the morning when i do turn on my heater? cause if the fans are on wouldnt that keep it from getting to the right temp.?
Thanks again for your help!
Bleeding
When you start the car in the morning, the fans should run ONLY if the compressor is running. The compressor only runs for air conditioning or defrost. There is a setting for heat and defrost which will also run the compressor. However, for heat ONLY, the compressor should not be running so your fans shouldn't be running either, unless your around 210° or higher.
