Is my tensioner bad?
Let us know what you find out, curious.
Well, they were checking the voltage output. Did the voltage (as measured by them) fluctuate up and down, or remain steady? And were your lights doing the pulsating thing during the check?
You may also just have a bad battery or something. If its not sealed, check the cells to see if one is dry.
Take the drive belt off and spin the alternator pulley manually, if it has play in it you may have a bad bearing.
Hope this helped.
Hope this helped.
