Changing window motor
150,000 miles and only had to change one. If your changing them often, there must be some other problem. Make sure the sliders are greased....
It's a easy DIY job. My advice would be to find a friend who has done it at least once before and then after that you can do them on your own.
However, the interesting point is that the 530T has a "resistence" setting, which basically determines when it should stop rolling windows up. Once a window gets to the top, the motor can't turn any more and the resistence goes way up. The 530T then shuts off. When a motor starts to die, it has a harder time rolling the windows up, thus causing more resistence. If the resistence is high enough, your window will stop rolling up, thus causing you to have to hit your window up switch 20 times to get it all the way up. On the 530T, I raised the resistence tolerance so that it definitely finishes rolling the windows up. Supposedly this decreases the lifetime of a new motor, however since my motors are very old, it's saving their life a little bit because I'm not having to hit the window up button 20 times. Doing that is a very quick way to kill the window motor.
Anyways, I'm still on the stockers. I'm going to buy some with the lifetime warrantee when I have to replace these tho, because there's no way I'm replacing the window motors more than once. PITA.
windows
