easiest way to remove a/c compressor?
i think the best way is to remove the top bolts first, because the compressor is kinda heavy, you can support it while you remove the bottom bolts. when putting a new one on its much easier to put the top bolts on first, but dont put them in all the way because mine was a bitch to line up all the bolts and thats with them all loose. have fun.
Just vacumn after install, fill with R 134a and Ester Oil. Ester oil is prefilled into compressor. Check your packing to find the rating of oil you need to use. Can all be bought at any auto parts store. Easy to do.
100% DYI
Now my problem is finding out why mine doesn't turn on. Works when turned on at relay. Computer shows Pressure sensor malfunction and there is not 5 volts at one side of the switch.
non slip to the tranny and overfilling it a bit?will this cause an ses light?
100% DYI
SUPER hijack by the way...overfilling the trans should cause it to eventually puke out the extra fluid, i dont know if it would throw any SES light.
While you are doing all this plug any open lines; Refrigerant/oil residue become acidic when exposed to moisture. Hell, even some tape will help. When compressors go they like to leave metal particles behind so replace the orffice tube and always put a new accumulator/dryer in.
