very strange fan noise
Have a very strange fan noise??
I have recently purchased a 01 Z28. I bought the car in the Houston summer heat and shortly after driving the car I noticed a fan noise that would come on as soon as the car started up. It kinda sounds like a turbo-charger. The fan will cut off after warming up after 5 minutes. When Im driving the car, the fan comes on after I run the engine hard. The fan then shuts off after the RPM's go back down. The only mod to the car is SLP LM exhaust.
My question is do all the LS1's do this or is this something I should be worried about? Any responses would be great....
I would look at the water temp is it really high at all. what dose your needle usually read under normal driving?? I dont hear that when I first start my car. Also turn on the car and see if you can see where the noise is comming from under the hood.
Huh maybe you have this. Have you taken the claps off and actually looked at it.
http://www.turbonator.com/index.html?id=adWordsCamaro
If this is it then i guess its a mod. Or vac leak, I would still take the clamps off and look anyways. I think I might try that thing also, maybe if i get bored.
