got the car dyno tested and now have ABS/ASR problems
Sounds like one of the abs wires got broke or unhooked when the car was strapped down.Look under the rear for any broke/hanging wires.(I'm not sure where the wire is on the rear).On the front,if you look behind the wheel/caliper,you'll see a wire going to the wheel hub along the A-arm.Make sure they're plugged in.
Make sure the sensors are plugged in tight at each rear wheel too. ABS light comes on sometimes after dynoing, but should go off by itself after a few miles.
