Sponsored by: CARiD
brake light problem
Old Oct 31, 2005 | 08:13 PM
z28_n_tx's Avatar
Default brake light problem
this is probably a minor thing but just wanted to see what was up with it... a few days ago i turned my car on and the abs inop and the asr lights were both on, so i turned the car off and on a couple of times but they kept sating on. i took it for a spin and 2 minutes in to the drive they went off and have not come on again...but when i go to set the hand brake, the light wont come on..however it does light upwhen i turn the car along with the rest of the panel.. any ideas???
Old Oct 31, 2005 | 08:24 PM
2K2WS6TA's Avatar
For the brake light, look at the switch on the hand brake, if it's stuck in the off position the light won't light
The ABS/ASR light I've had it too, after doing a burnout, or dropping the front wheel off the side of the driveway , if it hasn't returned, I wouldn't worry about it
Old Oct 31, 2005 | 08:35 PM
z28_n_tx's Avatar
thanks ill check that out
Old Nov 1, 2005 | 06:39 PM
z28_n_tx's Avatar
messed with the switch and nothing happened.....
