Sponsored by: CARiD
Buzzing coming from rear of car?
Old Nov 8, 2005 | 08:28 PM
Morbid's Avatar
Default Buzzing coming from rear of car?
This just started happening today it seems, it's a loud buzzing.. kinda sounds like a dremel on a really low setting. Doesn't matter if the car is moving or not, if the lights are on or not. It goes away when the car shuts off though. It doesn't get louder with speed or anything like that. It's sometimes goes away for a second, but comes back.
Sounds kind of like an electric buzzing in a way as well. If I get out of the car, I can still hear it. If I kneel down near the driver side rear tire.. I can hear it plain as day. Not so much on the passenger side.
I have no idea what might be causing this noise. Any ideas?
Old Nov 8, 2005 | 10:23 PM
2K2WS6TA's Avatar
Fuel pump?
Old Nov 8, 2005 | 10:39 PM
Morbid's Avatar
It's possible. Is that where's it's located? I'll try to get up under there and see if I can pinpoint it this weekend, if it's still doing it.
Old Nov 8, 2005 | 11:37 PM
ArcticZ28's Avatar
Yup, it's located in the rear on top of the tank.
Old Nov 9, 2005 | 01:47 AM
Sick14SecV6's Avatar
Mine is doing the same thing....Don't feel too bad. It doesn't seem like too big of a problem, I am going to upgrade fuel pump and filter to be safe.
Old Nov 9, 2005 | 07:23 AM
Morbid's Avatar
Awesome. Thanks for the help. I'll check it out as soon as I can. Are they fairly easy to replace? Something tells me it's not, being on top of the tank and all.
Old Nov 9, 2005 | 07:29 AM
M6HuggerSS's Avatar
fuel pump is on its way out......
Old Nov 9, 2005 | 08:58 AM
SUTTERERMAN85's Avatar
its the fuel pump. its normal. some are louder than others
Old Nov 9, 2005 | 09:00 AM
Morbid's Avatar
It wasn't making the noise today on my way to work, so it may infact be going out. Better to replace it now than be stranded somewhere. I just want to make sure it's the culprit.
Old Nov 9, 2005 | 09:44 AM
check your fuel pressure. i think its supposed to be like 41 psi idleing or something like that. if it runs fine i would worry about it. i put a new one in my old black formula and its a pain in the ***
Old Nov 9, 2005 | 10:34 AM
paper doll's Avatar
okay i have a loud buzzin gand it's the heat shield so check that
Old Nov 9, 2005 | 10:35 AM
paper doll's Avatar
do you have an aftermarket exhaust system? mine started doing it shortly after we replaced the cat back
Old Nov 9, 2005 | 10:37 AM
paper doll's Avatar
oh and another thing, did you try to put it in neutral to see if it would stop then?
Old Nov 9, 2005 | 10:55 AM
Morbid's Avatar
Right now my exhaust is stock manifolds to cats and to a chopped off y-pipe. The section of the y-pipe where it starts to turn towards the center is where it was cut off. So there's no exhaust back that far to be making that noise.
I heard it while driving, put the car in park and got out trying to pin-point it. Park is basically like neutral anyway, minus the ability to roll the car.
Old Nov 9, 2005 | 10:59 AM
paper doll's Avatar
my buzz only stops if the car is in N , drive park reverse what have you , all make that noise, our exhaust was off for a week and it still made it, but we found out that it was the heat shield in the back
Old Nov 9, 2005 | 11:31 AM
Morbid's Avatar
If it was the heatshield, wouldn't the tone/pitch of the buzzing change as the RPM's do? Mine was/is constant with no change.
