Sponsored by: CARiD
Car wont start
Old Nov 12, 2005 | 05:23 PM
GuitsBoy's Avatar
Default Car wont start
My car wont start. I disassembled and cleaned out the clutch safety switch, I even jumped the clip with a paperclip. I removed vats with hptuners. I hear the fuel pump cycle. Ive got plenty of battery. I even swapped the ignition and starter relays. ALl the fuses look good. What else could I be missing?
Old Nov 13, 2005 | 09:11 AM
GuitsBoy's Avatar
Well last night no matter what I tried, she wouldnt start. Even gave it a couple hours inbetweeh and went out to dinner with some friends, when I got back she still wouldnt start. This morning however, she started right up on the first try. WTF?!?!? Any ideas on what to check so that this dosnt happen to me away from home?
Old Nov 13, 2005 | 09:25 AM
BrandonDrecksage's Avatar
when it didn't start..what did it do? click? turnover but not catch? security light flashing? just saying a car wouldn't start isn't descirptive enough
Old Nov 13, 2005 | 09:51 AM
GuitsBoy's Avatar
Sorry, i thought i had mentioned that. No, no security light, but i did remove vats with HPTuners just incase. The starter did not even click. The fuel pump did cycle and the lights shut off as normal when you turned the key, but no action from the starter. Basically it acted the same as if you were to try and start the car without pushing in the clutch, but like i said, i did clean out the clutch switch and even tried shorting it with a paperclip. For what its worth, I had just washed the car, so maybe water has something to do with it. Or maybe the cold. But it had just started an hour earlier before the problems arose last night.
Old Nov 13, 2005 | 11:05 AM
2K2WS6TA's Avatar
Do you have an amp with the power lead on the battery + terminal, check it for corrosion, if it's gotten loose, or something like that, sometimes it's enough to prevent the starter from working, but not the fuel pump, lights, etc etc
If it happens again try taking the amps power wire off and reconnecting the + without the amps power wire.
Used to happen on my IROC sometimes, especially after I'd wash it
Old Nov 13, 2005 | 11:10 AM
GuitsBoy's Avatar
Nope, its a new battery with gold plated terminals so theres no corrosion. I have a feeling its the starter or the solenoid. From time to time I was getting what sounded like the starter teeth bouncing on the flywheel cause they wernet engiging properly.
Old Nov 15, 2005 | 03:00 PM
Abe99's Avatar
Try hitting the starter a couple of times with pipe or something, sometimes when the starter is going out it tends to get stuck and will not do anything.
Old Nov 15, 2005 | 03:13 PM
GuitsBoy's Avatar
I forgot to post back up. After being unable to start it after hours of trying, i went to bed. The following morning, I got up and it started the very first try. My current guess is the starter, although it hasnt gotten stuck again since. I pulled it out and cleaned out the clutch material and put it back. So far so good, but just to be on the safe side, i ordered a new one from valvegod on monday. Thanks for the replies.
Old Nov 15, 2005 | 04:22 PM
steveo346's Avatar
i was gonna say that it might have been the ignition switch but im not sure if our new ls1 have them...i know my 72 camaro has it and it was doing the same thing
Old Nov 17, 2005 | 01:43 PM
Justin01SS's Avatar
I had a similar problem with my 01 SS. Under the hood is a fuse box, well 2 actually. One of them has relays for IGN and Starter. Try swapping them since they are the same relay and see if it fires up. It fixed mine when i did this. IGN requires much more juice so u can run this way until u find a new relay. Give it a shot, only takes a few seconds to get it out. GOOD LUCK!
Justin
Old Nov 17, 2005 | 02:04 PM
GuitsBoy's Avatar
Justin
I had already done this the night I couldnt get it started, but no joy. I should receive my starter today, but i really havnt had sny problem since that night.
Old Nov 17, 2005 | 03:20 PM
'Trust''s Avatar
Sounds like your starter to me man
