LT1 overheating
It is a 96 LT1 trans am.
I checked all three relays. All good. The 2 fuses are good. All grounds are good. If i jump the relays, the fans kick on. If the car is running, and i umplug the engine coolant temp on the water pump (so the PCM thinks the car is like 300+ degrees), in a short time both fans kick on.
Other wise the fans seem to never turn on. I can watch my gauge go to something like 230 degrees... and occasionaly it will creep back down to 190's. So im thinking the ECT sensor is bad.
What else can i do to figure out why my coolant fans are not turning on? And is this the sole reason my car could be over heatings in stop and go traffic? Does it douns like a ECT sensor?
THanks
NIck
When getting stuck in traffic on I-85 the temp will go up quickly, but if I get in the shade of a tractor trailer, the temp will fall back down?
