Sponsored by: CARiD
best ATF fluid?
Old Nov 22, 2005 | 10:53 AM
curtisad's Avatar
Default best ATF fluid?
Royal Purple? Amsoil? My dad swears up and down about Amsoil. I use Royal Purple for everything in my car. Any comments?
Curtis
Old Nov 22, 2005 | 11:10 AM
jkichline's Avatar
So far, there are 92 comments here...
Royal Purple?
EDIT:
Sorry just realized that this thread is engine oil, not tranny fluid.
Old Nov 22, 2005 | 11:50 AM
LS1-450's Avatar
Curtis
Both are good ATF's. I use Amsoil in the transmission & Royal purple in the rear end.
Old Nov 22, 2005 | 12:38 PM
narc's Avatar
ATF is ATF. just make sure its dexron III
Old Nov 22, 2005 | 05:47 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I always stick with NON-synthetic (conventional DexIII) trans fluid. There are arguements for both sides, but when FLP build the trans for my WS6 they said to avoid any synthetic fluid in the trans, or any 4L60E for that matter. I follow that same advice for all my auto transmissions now.
I normally use Valvoline DexIII conventional ATF.
Old Nov 24, 2005 | 12:54 PM
RDISADEIFAN's Avatar
Ive used synthetic tranny fluid twice in two different cars and ended up draining it out and putting in regular Castrol DexIII back in.
Old Nov 24, 2005 | 01:14 PM
LS1-450's Avatar
What problems were you having?
Old Nov 24, 2005 | 06:54 PM
Cheater's Avatar
b&m with lucas transmission fluid
Old Nov 25, 2005 | 12:53 AM
It started to shift poorly like it was slipping,in both cases I used Mobil synth. atf.But as soon as I put back in regular dex. the shifting was back to normal.
Old Nov 25, 2005 | 10:06 AM
LS1-450's Avatar
Huh, that's interesting. If mine ever does that, I'll change fluids first. Thanks for the information.
Old Nov 25, 2005 | 01:57 PM
maddboost's Avatar
Any brand of Dexron III I would recommend. Specifically Valvoline is what I use. Stay away from synthetic trans fluids such as Royal Purple and Red line. They are too slippery and can cause premature wear of the transmission.
