Sponsored by: CARiD
How to remove headlamp switch?
Old Nov 23, 2005 | 11:45 PM
ls1_bc's Avatar
Default How to remove headlamp switch?
I think I have an electrical short behind my headlamp switch.How do I remove it? Do I have to remove the bezel around the guages first.Or does the AC vent pop out?
Thanks
Old Nov 24, 2005 | 07:59 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Thanks
Pop out the trim plate, should be 2 screws holding the
headlight switch in place. Two connectors to switch, one
on left should be dimmer switch connector.
This is what the Helms manual shows for a 2000.
Old Nov 24, 2005 | 01:46 PM
ls1_bc's Avatar
thanks gwj........by pop off the trim plate do you mean the vinyl that goes around the switch that is also a AC vent?
Old Nov 25, 2005 | 07:15 AM
gwj's Avatar
gwj
Yep. Out of curiosity I took mine off yesterday. There is
a tab on either side of the trim (inside) that hooks to the
dash.Just ease the trim off with your fingers and you'll see
the switch.
