Sponsored by: CARiD
headlights flickering
Old Nov 25, 2005 | 10:47 AM
meSSman02's Avatar
Default headlights flickering
my headlights just started doing this recently it comes and goes i noticed my alt gauge also surges with the headlights. bad alt or tensioner or belt? need help. thanks
Old Nov 25, 2005 | 10:52 AM
chaman's Avatar
Mine doing this also. Someone told it could be the alternator. Hope someone chimes in with good advice!
Old Nov 25, 2005 | 12:05 PM
ls1_bc's Avatar
Exact same problem here.I do however have a slight burning smell in the car when this happens. I think there may be a short behind the headlamp switch.I think the reason the lights go on and off is that there on a relay not a fuse. My battery and charging system seem to check out ok and all other power options are working 100%. I'll pull the switch out later and report back.
Old Nov 25, 2005 | 04:38 PM
1sick'98WS6's Avatar
ive had the pulsing headlight for a while now, it only seems to happen when im at a higher rpm
