Sponsored by: CARiD
tranny leak
Old Nov 27, 2005 | 08:08 PM
IownedU's Avatar
Default tranny leak
The other day i noticed i was leaking some transmission fluid from the 'back' of the transmission...i believe it is just the gasket between the transmission and drive shaft "area" (not good with terminology) i was wondering if this was pretty common and if anyone has some instructions on how to swap the gaskets. I dont really want to drop the tranny but if thats what i have to do them so be it...need some advice and instructions...thanks!
Old Nov 27, 2005 | 08:50 PM
CRAGER's Avatar
Administrator
Probably the rear seal where the driveshaft goes into the tranny. They do go out, but it only costs about $4 from an autoparts store.
You just pull the driveshaft out, pry out the old seal and pop in the new one.
Peace,
Craig.
Old Nov 27, 2005 | 09:40 PM
IownedU's Avatar
do you know the part number or the actual name of the seal that goes there?
Also what are some other spots that might be leaking from there.
I want to replace any gasket around there that might be a potential leak problem in the future to avoid having to do it all over again..might as well spend $10 on a gasket then $2000 for a new tranny...thanks guys!
Old Nov 28, 2005 | 11:09 AM
zoomer02's Avatar
I think it is called the rear seal or rear oil seal. The parts guy will know what you are talking about. Other seals in the area, I had the spedometer sending unit spring a leak. There is an O-ring around the speed sensing unit, but mine was leaking from the electrical connector so I had to replace the whole thing. Good Luck. When you take the U-Joint off be sure to put some tape around it so that the sleeves don't come off and spill needle bearings all over the place.
