Sponsored by: CARiD
blinker out
Old Nov 29, 2005 | 03:35 PM
zamboxl's Avatar
Default blinker out
hey all my driver side blinker stoped working the light still comes on but it just wont blink. what could that be a fuse???
Old Nov 29, 2005 | 04:17 PM
jkichline's Avatar
If you have a bulb out, it won't blink.
Did you check all of your dual element bulbs? A good way to tell if one's out is to put your 4-ways on and see if the left is the same intensity as the right. There are two dual elements in the tail light and I'm not sure what's up in the marker but I would check that out, too.
Old Nov 29, 2005 | 04:30 PM
AncientRgn's Avatar
double
Old Nov 29, 2005 | 04:32 PM
AncientRgn's Avatar
Change the fluid be carefull with them muffler bearings also
Old Nov 29, 2005 | 04:41 PM
zamboxl's Avatar
smart ***
Old Nov 29, 2005 | 06:47 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
My blinkers go out so frequently that I do not even change them any longer. My front left has been out for months. And it will stay that way too.
Old Nov 30, 2005 | 03:08 AM
AncientRgn's Avatar
Originally Posted by zamboxl
smart ***
Sorry, I had to
Old Nov 30, 2005 | 12:21 PM
zamboxl's Avatar
ok well i check the hazard thing and they both blink equally but my left blinker is still out its not the bulb, it just wont blink.
Old Nov 30, 2005 | 12:29 PM
zamboxl's Avatar
mufler bearings where fine but the pick up tube for the dry sump flux capasitors injection system is going out so i think i need a new one
Old Nov 30, 2005 | 05:11 PM
lgobraves's Avatar
i replaced the bulb when mine did that and it has worked fine for about 3 months now
Old Nov 30, 2005 | 06:24 PM
Phoenix 5.7's Avatar
there is a blinker thing under the dash that goes out for sometimes. do a search for thermal blinker, and you might find what im talkin about
Old Nov 30, 2005 | 06:47 PM
coldboot's Avatar
Unless both blinkers are staying on and not blinking then do the following:
Replace the bulb for front the blinker on the side that has the issue, if you still have an issue then replace the back bulb on the same side for the blinker (in the back of the car). Had the stuck on (no blinking) issue with my blinker several times, the bulbs are cheap so I recommend you just buy them both and I just did it in parking lot (caution you will need long arms lol).
Old Dec 1, 2005 | 05:12 AM
jkichline's Avatar
Did you check both front and back?
Here's a thread about what Phoenix57 was talking about, there's good information here. I bet this will probably fix your problem:
Thermal Blinker Thread
I also have a right blinker problem and thought it was a bulb in the rear. I replaced it and it was fine an hour and then stopped blinking again. Then I thought that the harness was corroded, so I steel wooled the hell out of it and put some silicon grease in there and put the bulb back in. It was good for an hour, and is not working again. Now I'm thinking it could be a loose wire or something in the harness. I use the 4-way trick to check them and its the same bulb every time. A couple years ago, my tail light housings failed and took on moisture to the point that I could have had fish living in there. I put the newer 98-02 style lights on but never replaced the harness. Maybe that moisture problem is finally starting to kill the harness behind what I can see. Anybody ever have harness problems?
Old Dec 1, 2005 | 10:40 AM
zamboxl's Avatar
well one thing i did notice is about a month or two ago when the light started going, sometimes it would blink sometimes it would not, it pretty muched blinked when it felt like it till it died all together, also the little yellow light thats on the front bumper on the driver side is also not working, so yea i guess i'll change the front and back bulbs and take it from there thanks.
