Things to do before storing your vehicle
I usually don't change the oil before I put it away though... Instead, I let the old oil (Mobil 1 with about 3k miles on it) sit in the oil pan through the winter. Then, in spring when I'm ready to take it out, I do an oil change before I fire it up for the first time.
Anyone disagree with this?
1) wash and wax the car
2) fill up the gas tank
3) start it up for about 20-30 min on a weekly basis to keep everything flowing and charging.
4) i drive it up and down the drive way in every gear (for autos)to keep them lubricated.
5) do some soft and hard braking
6) take cover off and open doors and windos to air out.
I am also wondering about this, or will there be a sludge problem? Anyone?
no sludge problems......AS long as you use fully synthetic oil and start it at least once a week and let it run for about 20-30 min.
Spare wheels & tires are a good idea for LT storage. Tires can flat spot, but it takes some time. I would not leave a car on jackstands. Leave it loaded as designed. $0.02
oil will be change right away and a few times over quickly.
Anyone thing i'll have any problems?
I like to have reasonably fresh oil in my motor when I store it. As you drive the acid content of your oil gradually increases and acid (even weak acid) can start to etch (corrode) cylinders, bearings, ETC. during storage. I use a can of seafoam for my fuel stabilizer. That way you automatically clean the fuel system when you burn the first tank of fuel after storage. A lot of people use sheets of fabric softener in the interior to discourage mice from taking up residence there. I prefer to use a battery maintainer to keep the battery charged. Letting it discharge shortens it's life.
Here is the website where it talks about how it works and where you can get it....
http://www.damprid.dsiwebbuilder.com....asp?cat=40019
also good for seals, is beeswax actually use a thin coat to keep it flexible and feel like new, works great on t-tops since those are always the first to go.
