Starting problem
And how does it run once it's started? Any other issues, or just while cranking/first firing up?
Most of my cars don't start exactly the same every time, including the Camaro. Sometimes slightly longer cranking when cold, and sometimes it seems to kinda "halfway" catch while cranking, so I release the key, then a split second after I release the key it fully roars to life, and runs/idles strong and perfectly normal. Is that what you have experianced? So long as it jumps right up to a strong idle, I wouldn't be too worried about a little abnormality during cranking...especially if it only happens on cold starts. This happens to me once in a while on a cold start. My Camaro sits a lot, anywhere from a week to a month between restarts so I'm sure that's part of the reason.
Weather, how long since the last restart, and engine temp at startup all play a role. But even when conditions seem identicle, not every startup will be exactly the same.
