interior lights stay on
Also, the driver's door lock doesn't work electronically now - I either have to use the key or manually slide the lock.
I tried pulling the courtesy fuse, which will shut off the interior lights, but that also takes out the power windows and locks, so that's not a solution.
Could it be that the driver's door is not fully closing?
My driver's door does require a hefty pull to fully latch.
Any ideas?
Sounds like you have a GREMLIN!!!! Those are so much fun........not really.
