Sponsored by: CARiD
brake light!
Old Dec 1, 2005 | 09:33 PM
raceking33's Avatar
Default BRAKE Light!!!!!!
Okay I have a 95 M5 Camaro Convert. and everytime I put the e-brake off the little brake light still stays on even though the brake handle is down? Do any of yall know what the problem might be?????
Old Dec 1, 2005 | 09:43 PM
ss rally red's Avatar
Check the level of the brake fluid resivour,if it is at the low/add mark you need to look at the condition/wear of the pads/shoes
Old Dec 1, 2005 | 10:11 PM
black01_WS6's Avatar
low brake fluid like ss ralley red said.
Old Dec 1, 2005 | 10:22 PM
raceking33's Avatar
wheres the resivour located on the car? is it hard to get to? and what style fluid goes in?
Old Dec 1, 2005 | 11:03 PM
dot 3 brake fluid, itson the drivers side by the windshield. you can't miss it.
Old Dec 2, 2005 | 10:56 AM
raceking33's Avatar
thanks!!!!
Old Dec 2, 2005 | 11:40 AM
777's Avatar
777
There's a sensor under the console where the brake touches when it's down. you may need to replace it. Take a look at it. My camaro did this and I had full brake fluid and new brakes.
Old Dec 2, 2005 | 06:02 PM
raceking33's Avatar
thanks 777 becuase i just put fluid in it and the light is still on.
Old Dec 4, 2005 | 02:53 AM
TheBlurLS1's Avatar
That's what she said...
That switch is plain as day if you remove the center console. To do this, you have to remove the shift ****, boot (be VERY CAREFULL with the plastic retainer), remove the screws from under the dash, under the ashtray (i think), and under the change holder in the console (sneaky bastard).
I'm assuming its the same as a 98
