gas mileage
2.My car has a small leak in the exaust manifold gasket. could this affect mileage?
3.Do these cars have a low gas warning light?(I see no warning light turn on when I am below quater tank and farther)
4.What type of gas do you use (the owners manual reccomends premium...but do i have to?)
If anybody could answer these question that would be great. thanks
2.yes that can affect gas mileage along with the computer detecting false knock from the leak and the car being down or power.
3.No our cars don't have a low warning light. In the winter i don't recommend letting the tank get below 1/4 full.
4. With the LT1's the compression is 10.5:1 with it being that high thats why the recommend 93 octane to pervent detionation.. some people get away with using "regular" gas but i've never tried it.
Hope this helps.
another question: would middle grade gas be okay, I'm not looking for preformance now, but i dont want to hurt the engine
oh yeah, unless you really trust a mechanic always double check the problem with another mechanic...I took my car to a dealer to find out why my car died, they said it was a bad fuel pump 900$ fix, took it to another smaller shop..300$, before they worked on it they found out i was out of gas 5$ fix.
This is my first car, i'm used to driving my dads LeSabre. Big Difference.
When gas was over $3.00 a gallon I tried running mid-grade on a long trip. I found that the reduced gas mileage I got was more than what I saved buying cheaper gas. My mileage was at least 10 per cent lower but I was only saving about 3 percent on the price of gas (10 cents per gallon).
It's nice to know you can use other grades in an emergency but you should stick to premium when it's available.
the LS1 has a knock sensor that can supress this detonation. therefore, running less than 91 octane in an LS1 will not necessarily harm the motor. the motor will retard timing in order to supress this detonation. what does this mean for you? a HUGE decrease in fuel economy and horsepower. for best engine life, best fuel economy and the most horsepower possible, run 91 octane or more. i want to add that running 93 octane will NOT give you better mileage than 91 octane. octane is not a power adder. you only need 91 octane, but a little more will not harm it. FWIW, my local sunocos carry 91 and 93 octane. i buy 91. there's no gain out of the additional 2 octane so why spend the extra 5 cents a gallon? it adds up when you drive 400 miles a week like i do. FWIW, my last fillup was 22 mpg on a mostly stop-and-go route.
it won't do ****. octane is NOT a power adder. all you NEED is 91. any more will NOT give you a single horsepower or mpg. all octane does is retard the fuel igniting. running, say 100 octane ain't good for a stock motor. run 91 or 93, whatever is available in your area. anything else is like pissing on your feet. it's just unnecessary and it's a bad idea.
i've never taken an all highway run on my car, but i have high hopes. i'd imagine LT1 cars would get slightly less mileage than an LS1 because our newer aluminum motors just seem to get excellent mileage compared to most V8's out there. i'd always see an alumium motor getting better mileage than an iron motor just because it's lighter. that and the LS1 has 4 less cubes and gets into the powerband less daily driving it normally (you gotta rev the LS1 to 3500-4000 rpms before you hit the powerband whereas an LT1 gets deeper into the powerband at lower rpms making it work harder per rpm than an LS1 = less gas mileage for an LT1).
