alarm no longer works but keyless entry does?
i hope this is an ok place to post this. if not please move to the appropriate place.
ok i just did a clutch change on my car so I was in the center consule area. my alarm no longer works but my keyless entry does and my parkign lights no longer flash when i use the keyless entry. all this worked before i started the clutch change. this doesnt make any sense to me since its all controlled by the BCM. is it a seperate part of the BCM? i know you can have keyless entry and not alarm on a car. ive tried entering diagnostic mode of the BCM. those of you with a service manual can read how to do this in the BCM section. anyway the car would not enter the BCM diagnostic mode. where is the BCM located? do any of the wires run through the consule area? i havent doubled checked the wires to make sure everything is still plugged up if it is in the center consule area. i will do that tomorrow but im looking for other thoughts and input as well. thanks for any help.
oh the car is a 96 formula M6. late build date.
