Sponsored by: CARiD
Need a torque spec...
Old Dec 15, 2005 | 07:45 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Default Need a torque spec...
I had to loosen those two bolts that go through the tranny into the oil pan to drop the pan a bit. Forget the size of them...13mm or 15mm?
Anyway I have searched and found nothing on what it should be torqued to. I remember reading a while ago though thats its around 35 lb ft?
Thanks for the help.
Old Dec 15, 2005 | 08:19 PM
67Ranger's Avatar
if they are the long ones that go into the rear cover they are 12nm (about 8 ft-lb i think)... if they are the pan bolts, then its 18. For future refrence, http://www.ls2.com/boggs/torques/eng...tm#Application
Old Dec 15, 2005 | 08:24 PM
Lithium's Avatar
No, its not the little ones or the oil pan bolts.
They go through the tranny into the oil pan...
Old Dec 15, 2005 | 08:45 PM
Lithium's Avatar
Is this right?
Tranny to Bellhousing bolts - 26 ft lbs?
Old Dec 15, 2005 | 10:35 PM
Lithium's Avatar
bump...anyone?
Old Dec 15, 2005 | 10:42 PM
TheBlurLS1's Avatar
That's what she said...
37 ft/lbs DUH!!!
This is what i though was right, but i checked ls1howto.com anyway He has a whole page with specs on it.
http://ls1howto.com/index.php?category=1
Hit controll F and type housing if you dont believe me
Old Dec 15, 2005 | 11:01 PM
Lithium's Avatar
Your a good man!
Thank you.
Thats the first place that I looked actually. I was not sure if that was what I was looking for or not though...cause I dont know what the hell its called
