Sponsored by: CARiD
Turn signals
Old Jan 1, 2006 | 11:55 PM
slowtealz28's Avatar
Default Turn signals
I did a search but it didn't bring up exactly what I was looking for. Just a simple question, if both turn signals flash quickly, but all of them are flashing on the outside, what's the problem? Do I need new bulbs or is there something else wrong?
Old Jan 2, 2006 | 01:45 PM
komik's Avatar
You might want to check the relay.
Old Jan 2, 2006 | 09:31 PM
bww3588's Avatar
relay? where is that at? how do you check it?
Old Jan 2, 2006 | 11:52 PM
ZeeVert's Avatar
The flasher is sometimes called a relay. On Camaros it's supposed to be under the driver's side dash. It's about an inch in diameter and an inch long, with two prongs at right angles to each other. It can have a metal or plastic housing.
