need help
If the O2 wasn't working, the PCM probably dumped a bunch of fuel into the motor "limp home". If you have cats, they could be toast.
Also the O2 sensor could be gummed up after not being used for a period of time and it's wrong properly now.
I would change the plugs and try replacing the the front 02 sensors. You can swap the back sensors to the front to see if that helps.
Last thoughts, if the harness was "plugged" tramatically, might want to check the harness, it's possibly could be damaged.
You also might want to find out how that O2 sensor came out!
