Sponsored by: CARiD
problems with drivers side running light, and a leak
Old Jan 9, 2006 | 03:03 PM
narc's Avatar
Default 2 problems i need to fix? a little help please
http://i14.photobucket.com/albums/a3...8/P1010497.jpg
ok well the first problem is my drivers side running light. it went out a month ago and i changed the bulb and it was fine till now. as you can see the connector has corroded..Where can i buy a new connector? and what is all needed to change it out? splicing etc.... anyone got a write up?
http://i14.photobucket.com/albums/a3...8/P1010498.jpg
http://i14.photobucket.com/albums/a3...8/P1010501.jpg
http://i14.photobucket.com/albums/a3...8/P1010500.jpg
the other pics are pics of a leak but im not sure where it is coming from? seems like the rear main? where the engine connects to the trans? what does it look like to you?
Old Jan 9, 2006 | 03:23 PM
thunderstruck's Avatar
that leak could also be from the transmission input. it there enough fluid that you can see if it is engine oil or trans fluid?
Old Jan 9, 2006 | 03:34 PM
narc's Avatar
ya its engine oil..
Old Jan 12, 2006 | 03:03 PM
Dragonslayer's Avatar
Default Drivers side running light
I have the same problem. It all started when I hit an animal and cracked the turn signal bezel...every time it rains, the light goes out. I pull the old bulb out and it's wet. Try replacing the light bezel itself and you should stop having to replace it so often.
