Sponsored by: CARiD
temperature
Old Jan 10, 2006 | 02:43 PM
josh1107's Avatar
Default temp question
just wondering what temp your z runs at. just got my 98 z and want to make sure everything is working correctly.
also looking for a good tire for the 16" rims
thanks
josh
Old Jan 10, 2006 | 03:05 PM
2001NBMZ28's Avatar
Probably fine, 98's were blessed with an accurate gauge - 99's and up read just under 210 all the time once warmed up. You think it's too cool or too warm?
Old Jan 10, 2006 | 03:08 PM
andypdbz's Avatar
i still have the stock 16' rims, i use the BFG KDW, they work pretty good
Old Jan 10, 2006 | 03:30 PM
blkZ28spt's Avatar
Search the appropriate section for tire information.
The most straight line traction comes from a Nitto NT555-R extreme drag radial on the rear tires. For the money Kumhos are pretty good. I got mine for $88 each shipped.
Old Jan 10, 2006 | 06:27 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
With a stock t-stat and stock fan settings, your running temps will range between 190-230*F. Actual temp will depend on outside air temp, and stop and go traffic vs. open road cruising. Obviously, the cooler end of that temp range will be in cool/cold weather during low rpm cruising at speed. Expect it to creep way up in hot weather and/or heavy traffic.
Old Jan 11, 2006 | 10:06 AM
josh1107's Avatar
thanks for the good info, i thought the temp seemed a little low, right above the low mark of 160(i think its 160).even when crusing or sitting in drive thru. outside air is 45 degrees though.
Old Jan 11, 2006 | 10:48 AM
RPM WS6's Avatar
While it’s true that the ’98 temp gage does actually function, rather than the "dummy light" gage of the ‘99+ cars, it’s still not dead accurate on exact coolant temp. Only way to really tell is with a scanner.
FWIW, when my ‘98s gage reads just slightly above that low mark you mentioned, my temp is showing 190-195 on my scanner.
Old Jan 11, 2006 | 09:16 PM
josh1107's Avatar
ok, sounds good, thanks
josh
